thoughts on this build / cam suggestion 406sbc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-30-2013, 01:22 PM
BigEd36's Avatar
Project89, since you've stated that this will have a forged rotating assembly going into a bowtie block, I'll throw this out as just something to consider. In Scat's standard weight forged cranks for 350 mains, you can get a 3.8" stroke setup for either 5.7" or 6.0" rods. The extra .025" on the stroke radius would put the stack height at 9.025" with a 1.425" compression height piston, so the block wouldn't need to be decked to get a .000 piston deck height with 1.425" CH pistons. With the 4.155 bore, it would equal a 412" engine. But, since the money is being spent for a forged crank, why not go to a 3.875" stroker crank (for the same $$$), with a 4.155 bore would make a 420" small block. Even a very mild build with 420 cubes will make your HP goal. Here's the Scat listings from the new catalog showing their standard weight forged cranks for 350 mains 1 pc seal blocks:
  #17 (permalink)
Old 12-30-2013, 06:38 PM
vinniekq2's Avatar
get the heads flowed so you know its limits,,,,
New Build Carb suggestion 1971chev Engine 0 10-30-2013 12:26 PM
350 TBI build, cam and compression thoughts Northern Chevy Engine 15 02-17-2013 09:56 PM
406sbc new cam 306s coil bind questons matt921 Engine 6 02-11-2013 08:58 PM
Suggestion of cam Spikejl31 Engine 15 01-29-2011 09:37 AM
406sbc vortec heads cam? 82Scottsdale Engine 15 12-05-2008 11:39 AM
