Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thoughts on a cam
Old 06-20-2012, 03:31 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
camshaft
would you consider using a flat tappet solid cam?smoother idle and good throttle response.Talk direct to comp or the manufacturer you choose.Spend a little time explaining "exactly" what you expect. Ask three times and see where the overlap comes,pun intended.Lobe separation angle and intake lobe centre line are just as important as lift and duration.With AFR heads you dont need a lot of cam. Talk to afr and look at their website for results they get with their products.
AFR was an excellent choice,your engine will make a lot of usable power
