Thoughts - Comp Nostalgia Plus N+LS6 Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 11:53 AM
Considering a Comp Nostalgia Plus N+LS6 Cam 11-670-4 for 454.
The advertised duration is 276/283 and the lift is .530/.524
Its going in a 1970 Chevelle. Its a 1978 361958 Block and 336781 Heads. It is running flat top Speed Pro HyperEutectic pistons with 8.0 to 8.5:1 compression. Backed by a TH350 and 12 Bolt Posi with 3.73 gears. My only vacumn demand is power brakes.
Looking to play... Not really planning to race it. Just want to have some fun off the line.
Has anyone had any experience with this cam?
Old 02-26-2008, 01:39 PM
I think the compression will be closer to 7.5:1 with your setup.
942cc cylinder
120cc chambers
10cc gasket
5cc deck height
6cc valve relief
Your compression is way too low for that cam. 9.25 to 9.5:1 would be ideal.
Considering the gear and compression ratio, I would recommend a cam with 212 to 216 on the intake and 220 to 224 on the exhaust with 108-110 LSA.
that cam has 229/236, 112 lsa, with 1800 to 6200 rpm power band.
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 06:12 PM
Cam stuff and your thoughts bukweet Engine 4 05-19-2005 08:26 PM
'74 Corvette 454 dyno results- Comp Cam XE 274H questions Bob Turner Engine 12 05-19-2005 11:59 AM
Will stock valve springs work with a comp 268H cam? Mike_82 Engine 7 12-22-2003 04:35 PM
BBC Comp cam EX274H, Impala5967 Engine 2 10-01-2003 09:53 AM
