Joe, it shouldn't be a nightmare. You have to make sure that everything you are getting is Vortec compatible. You also need to understand what makes a Vortec a Vortec so you can understand what makes them tick. I believe the exhaust ports on a Vortec are about .200 inches higher than a standard head. Make sure your headers will clear everything being up that much higher, things like framerails, steering linkage, etc.
you are correct CRD i do need to learn more about vortecs.i saw in their add that these heads could be used with basicaly any intake manifold,and i jumped on it.i did not do enough research...
Joe, here's a real nice article on the Vortec. Look at the pics showing the difference in intake port height. Hope this tells you all you need to know.
http://www.customclassictrucks.com/t...evy/index.html |
Good! Now, do yourself a huge favor. Go to Scoggin Dickey and order their vortec top end kit. Vortecs that are modified to accept .520 or .540 lift cams, I believe they are set up with guide plates (not sure), head bolts, manifold bolts, gaskets, and vortec manifold. Nice setup. Orrrrrrrrrr, you could go to Edelbrock and get yourself a set of aluminum E-tec heads which are said to make 15-20 hp more than the cast iron vortecs. While you're on the phone with Edelbrock order up one of their manifolds to fit those E-tec heads.
| Dart Iron Eagle or Vortech Heads | bigjoedo | Engine | 31 | 05-14-2013 05:36 PM |
| Dart heads? | 75GMCman | Engine | 26 | 12-29-2009 10:52 AM |
| Need advise for trade. 408 short block for dart iron eagle block | sherman8r | Engine | 6 | 12-06-2009 04:37 PM |
| Dart Heads | awsome 502 | Engine | 9 | 05-26-2007 08:42 PM |
| dart heads | crusherdbuzz | Engine | 6 | 05-14-2007 11:47 AM |
