While the thumper cam is a bit big for those heads it'll run just fine. The compression is what worries me, even on 93 octane that compression with those heads will be hard to pull off. I hope you have a lot of gear and a light car.
Dropping the compression down to 9.5:1 would be ideal if you plan on running 87 octane.
