hey,
My first concern would be the edges of the rod bolts touching or striking the cam lobes because of the larger stroke 383 crank. Hopefully one of these guys have done a similar build to iron the details out. |
I'm having my machinist double check everything - just to be safe (including clearances, valve-train geometry and piston-to-valve clearance). FWIW, the engine is coming out to investigate low compression on one cylinder - so it's a good time to make the change. There are about 1k miles on the setup right now. I just want to make sure this cam will pull pretty well down low. I also want to cruise at 1800 to 2000 RPM's - and I want the OD to work for this... Lunati assures me it will. I'm looking for some street experience to confirm. |
The reference for that cam = 3,000-7,000 rpms power range... Reference link: http://www.crankshaftcoalition.com/w..._compatibility I am not for sure the 3.73's and 29" tires is going to help enough. Does this help any? |
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Yes, it helps. Thanks so far guys.
Howards seems to be in the middle with lower lift and longer durations on their cams --- and Howards INSISTS that I use the 112 LSA. Comp, Lunati, and Crower all said 110 LSA. Howards suggest their 110245-12 cam: 224/230° @ 0.05" 280/292 Adv 0.501"/0.509" with 1.5 ratio 112/106 I currently have a 230/236 @.05" 274/286 adv .49/.49 hydraulic flat tappet. It does just fine cruising in OD at 1800 RPM's. It will accelerate mildly from there (no downshift for hills). I want a roller equivalent that is one step up from my current cam (XE274h). Suggestions? Last edited by Big Mouse; 07-21-2011 at 12:07 PM. Reason: I added more details to clarify my post... |
I am running that exact lunati cam in my 86 s10 but mine is a 350ci and I have no issues with mine but I don't have overdrive like you do so cruising down the highway at 55mph I am around 2500 rpm.
I am running 3:73 gears with a 3000/3500 stall and if I am in drive in town and I am under 2000 rpm the engine does not do very well so I just down shift to 2nd gear when I need to but highway wise that cam is killer with a good setup. I have very crisp instant throttle response and the torque is way awesome and with yours being a 383 it would be even more. As stated if your wanting to use the overdrive for highway you might want to go smaller on the cam. Mine does not like it under 2000 rpm very well and it will drive decent but not good. Hope that might help out in your decision you could go with the next smaller voodoo cam the 60111 it would be a really good cam as well. Guarantee there would not be a big drastic difference in horse power between the 60111 and 60112 cams but there would be a mild difference in how it would run in your combo. The other options you have look good as others have stated as well. Eric |
That is great feedback - thank you. I'm hoping the extra cubic inches will help me a bit. I'm also running a 4-hole spacer which may help boost the low end signal. Good stuff!
the 112 LSA will give you more vacume keeping the valves closed longer than a 110 LSA, so a 112 will have abit more low end torque for lower rpm crusing.. 110 still not bad but dont go lower than that, 109 and lower will be a little to much overlap and a little loss of compression as well
| hydraulic roller cam/mechanical roller lifters | cutlassryder | Engine | 3 | 05-01-2010 07:57 AM |
| SBC Factory roller lifter retro on non roller block | 383ram | Engine | 1 | 01-24-2009 07:16 PM |
| plz help,,,1988 vette 350 hyd roller motor can i convert it to hyd non-roller?? | tiresmoke55 | Engine | 20 | 05-24-2006 01:51 AM |
| Which is better Hydrallic Roller or Solid,Mechanical roller | dboyett38666 | Engine | 4 | 04-02-2006 08:59 AM |
| Hydraulic roller vs. solid roller cams? | chanson | Engine | 2 | 11-21-2003 09:30 PM |
