Thoughts on my 406 combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2010, 08:09 PM
I Have A 406 About 12 Compression Brodix 11x Heads Ported ,herbert Solid Roller 253 266 Duration@50 604 604 Lift On A 108 And A 750 Dominator Carb Super Victor Intake .what Kind Of Hp Will This Make? Should I Change Cam ? This Will Be A Street / Strip Car Probaly Drive No Further Than About 5 Miles Sometimes. Its Going In A 86 Monte Carlo Ss 3500 Converter And 4.10 Gears . What You Think Guys?
Old 07-27-2010, 11:53 PM
my87Z's Avatar
Veteran/Firefighter-EMT-I CRT
what trans is in that Monte, if it is the stock 2004R or 700R4 then you wont make it through more than one launch. the combo does't sound bad. i think the carb may be alittle small but the cam isn't too small. a 800-850 i think would do better, but ive seen nasty 406's running 750's before and doing it just fine. i'm just telling you what i would do, cause carb size it bound to spark and argument on this forum and i might think about a 4000 stall so my stall speed was 500rpm higher than the begining of my cams operating range
rough ballpark est would be 575hp/515tq, you could break into the 600's it all depends on how well the heads were done
Old 07-28-2010, 05:17 AM
Do you still have 5.56 rods in there?
Old 07-28-2010, 07:14 PM
i have 5.7 rods th350 w/manual valve body
406 combo, your thoughts 406 ss monte Engine 21 06-15-2008 07:19 PM
thoughts on 383 SBC combo mrdreex Engine 21 03-20-2008 01:43 PM
thoughts on this 427 combo bigwildgrin Engine 1 02-17-2006 11:21 AM
Need opinons on new combo for my 406 Steve karch Engine 9 02-02-2006 05:54 AM
406 critique my combo please!!! HoosierDaddy Engine 22 02-17-2005 07:53 PM
