thread sealant - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2009, 12:45 PM
pena0724's Avatar
thread sealant
I Just finished my rebuild on my sbc 350 i bought ARP Head studs and ARP sealant i used like i was suppose to ran the engine for five minutes shut down came back the next day and there was coolant on the groung and every i applied the thread sealant i pulled off the valve covers & head and there was it was coolant. i then decided to drain my oil and there was very little coolant, what should i do? next i bought all new gaskets oil and oil filter. Will i be ok by not droping the oil pan?
Old 04-27-2009, 01:15 PM
i dont know about your situation but i always use pipe dope on my head bolts.
Old 04-27-2009, 01:28 PM
pena0724's Avatar
My mechanic and i pulled the engine back out removed all studs and are going to use pipe dope do i need to drop the pan any othe suggestions i am open to all being this is my first rebuild.
Old 04-27-2009, 05:38 PM
T-bucket23's Avatar
Wiki Edits: 26
I had the same issue with the ARP sealant, I ended up using a Permatex sealer, sorry I dont remember the # and had no further issues. I have heard a lot of issue with the teflon sealant on arp studs.
Chet
Old 04-27-2009, 06:05 PM
pena0724's Avatar
are the head studs only suppose to be hand tight then backed off 1/2 turn
Old 04-27-2009, 07:10 PM
XNTRCI-T's Avatar
AKA Lee in KC
Dang it! I just assembled my blower motor with ARP sealant!!! I hope that's not the problem!!
Old 04-27-2009, 07:39 PM
pena0724's Avatar
is your leakin also out the head bolts
Old 04-27-2009, 07:43 PM
Well I used arp studs for my dart heads and my dad used teflon pipe tape nothing else and Ihave not had any problems. I was going to use some arp thread sealant but after reading this I am going to pass on using it. I will have to use some plain pipe dope. I have heard that the head studs have more of a chance of leaking then head bolts. I will probably swap out my head studs some day with arp bolts.
Eric
Old 04-27-2009, 07:53 PM
fast68's Avatar
likes chevy trucks & boobies
plumbers pipe thread dope in a can or squeeze tube
works great
always use it and never once had an issue with leaking bolts, ever.. and ive installed billion of heads over the years.
good luck
Old 04-27-2009, 08:04 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I have also used a permatex sealant/and pipe dope . both worked . Cole
Old 04-27-2009, 08:37 PM
God no!!!!!!!!!!!!!!!!!!!!!!!
I think your thinking of something else, the heads must be torqued to spec!!!!!!!!
Old 04-27-2009, 08:46 PM
pena0724's Avatar
just the studs that go in to the block
eloc431962's Avatar
Wiki Edits: 37
Good save robins44. missed that post glad you were there. you must always torque to specs. Cole
Old 04-27-2009, 08:50 PM
pena0724's Avatar
this is what i got from ARP http://www.arp-bolts.com/FAQ/Answers.html#_03
Old 04-27-2009, 08:53 PM
eloc431962's Avatar
Wiki Edits: 37
yep screw them dowm finger tight .then torque them with a torque wrench. Cole
