Thread Size on Edelbrock RPM Intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2012, 10:07 AM
Just putting my SBC back together & was wondering what the thread size is of the tapped hole on the top of the manifold right behind the carb.
Old 06-03-2012, 12:08 PM
Richiehd's Avatar
JS-70
if its the one im thinking, 3/8 NPT
Old 06-03-2012, 04:06 PM
Thanks Richie. That's what I suspected.
Old 06-04-2012, 07:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A quick FYI: The location of that hole will put most vacuum fittings in contact w/the fuel bowl of a Holley, so if you are using the port for vacuum and not just blocking it off, you'll want to use a low profile 90 degree fitting, maybe like Edelbrock p/n 8096 (shown below, male 3/8 NPT to female 1/8 NPT) to clear the Holley rear float bowl. Or you can use a carb spacer if there's room enough.
edelbrock air gap rpm intake problem marioflores Engine 10 01-03-2011 02:11 PM
Edelbrock Vortec RPM or Air RPM intake Hanks56Chevy Engine 8 07-19-2010 09:25 AM
weiand stealth intake vs Edelbrock rpm intake batman09 Engine 18 10-10-2004 01:41 AM
Intake thread size question? Jag Daddy Engine 1 07-29-2004 04:39 PM
Edelbrock RPM intake or RPM Air Gap? KeithB123 Engine 1 02-18-2004 08:08 PM
