Thread size & taper of 96 Dakota Ball Joints? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2014, 04:30 PM
Mutt's37Buick's Avatar
Does anyone happen to know the thread size & taper of 96 Dakota upper and lower ball joints?
Thanks
Old 01-17-2014, 04:47 PM
techinspector1's Avatar
Wiki Edits: 326
Thanks
Choose a manufacturer.
Find the part numbers in their catalog.
Find the phone number of the technical department or engineering department at the manufacturer's home office.
Make the call, give 'em the part numbers and ask for help.
The Following User Says Thank You to techinspector1 For This Useful Post:
Mutt's37Buick (01-17-2014)
Old 01-17-2014, 06:34 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Quite possibly the easiest solution would be to make a trip to the local parts store and take a caliper with you. You could measure it up and write down all of the numbers. Just a thought.
Kelly
Old 01-17-2014, 07:35 PM
BOBCRMAN@aol.com's Avatar
Chrysler used those same ball joints thru out the line from the fifties on.
Old 01-20-2014, 09:38 PM
johnsongrass1's Avatar
Race it, Don't rice it!
11/16 thread and 2"/foot taper.
Old 01-20-2014, 09:49 PM
Wiki Edits: 326
Kelly
Better than nothing, but still wouldn't tell you the taper per foot if you didn't know how to do the math.
Old 01-20-2014, 09:52 PM
No math needed with a protractor.
Separating a stubborn lower ball joint taper Slipangle Suspension - Brakes - Steering 32 05-06-2013 01:07 PM
ball joint taper reamer tomslik Suspension - Brakes - Steering 16 07-02-2010 08:13 PM
Converting wheel bearings taper to ball saltybob Suspension - Brakes - Steering 2 10-11-2007 10:45 PM
ball joints knuckles Suspension - Brakes - Steering 4 01-09-2005 09:41 PM
ball joints knuckles Introduce Yourself 2 12-28-2004 08:06 PM
