You are thinking correctly. Another thing about larger size thread..........you don't need to loop it through the thread guide on the top of your machine, just run it straight through from back to front. That is probably why going to smaller thread threw your tension off. The bigger thread had more tension on the top thread if it was looped through the top thread guide.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
The difference in needles will not make any difference in the tension. When you change the thread you need to make sure you have the thread pulled into the middle of the tension disks for the top thread tension. If you don't, the tension will be off until the thread is completely seated between the disks.
| Recent Interior posts with photos |
| bolt will not thread into hole ran a tap through several times | hotbrat | Garage - Tools | 32 | 03-23-2010 07:59 PM |
| thread life? | crystalbluevib | Interior | 1 | 02-21-2010 08:59 AM |
