-   -   threaded rod head studs (http://www.hotrodders.com/forum/threaded-rod-head-studs-115930.html)
53belair 05-12-2007 09:18 PM
i was wondering if i could take threaded rod and cut it into the right size and use them as head studs
would the threads inside the heads cause any harm?
Blazin72 05-12-2007 09:29 PM
Are you talking about using all-thread to hold the heads to the block? All-thread won't have the tensile strength to sufficiently seal the head to the block. That is not a good idea. :nono:
ARP head studs usually have a tensile strength higher than a typical Grade 8 bolt. I'd guess that most all-thread is Grade 3, maybe Grade 5 at best.
Chevrolet4x4s 05-12-2007 09:47 PM
why not just use stock bolts cheap and stronger than all thread
