threaded rod head studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2007, 10:18 PM
i was wondering if i could take threaded rod and cut it into the right size and use them as head studs
would the threads inside the heads cause any harm?
Old 05-12-2007, 10:29 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Are you talking about using all-thread to hold the heads to the block? All-thread won't have the tensile strength to sufficiently seal the head to the block. That is not a good idea.
ARP head studs usually have a tensile strength higher than a typical Grade 8 bolt. I'd guess that most all-thread is Grade 3, maybe Grade 5 at best.
Old 05-12-2007, 10:47 PM
why not just use stock bolts cheap and stronger than all thread
383 vs 350 TheCiscoKid Engine 86 05-03-2008 04:10 PM
5.7" vs. 6" savman1 Engine 30 01-20-2006 10:17 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 10:03 PM
detonation resistance, short or long rods? Old School Nut Engine 34 12-31-2004 01:23 AM
Threaded vs Pressed Rocker Studs (SBC) pgtr Engine 7 10-29-2004 08:10 PM
