I don't have an answer regarding thread sizes, but caution you not to use soft allthread found in Home Depot or Lowes (for example).
What I did on my Nova to install big block springs was compress the coils as much as possible, wrap and chain them to hold the compression and take another purchase on the coil to compress is further. It's a two step process, but for a garage job works and is relatively safe.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
bigdog7373: with the setup on a g body, I have to drop the threaded rod through the frame (The opening for the shock absorber bolt) to compress the spring. The threaded rod seems to be about 6 inches too short to allow me to compress all the coils when it's placed in the frame.
68NovaSS: I worry about the soft threads at Home Depot /Lowes as well. Luckily, none of the standard sizes they sell actually fit. One thought I had was to compress the coil separately from the frame, wrap the coil with a couple ratchet straps, then adjust and compress the coil even more with the spring compressor, then tighten the straps again. when it'll fit between the control arms I would drop the internal spring compressor through the frame, connect it to the compressed coil, attach the spindle, and slowly undo the straps and compressor until the coil is seated in the control arms. Thoughts? |
Just use the weight of the car to compress it. Put it in possition and slowly lower the car onto it til everythimg lies up and bolt it all together. Just be really carefull and you'll be fine.
| Spring Pocket Vs Spring Size vs valve lenth Help Needed | swompz | Engine | 16 | 05-30-2012 10:25 AM |
| Threaded Plug size | LBL | Engine | 5 | 03-13-2012 01:19 PM |
| threaded rod head studs | 53belair | Engine | 2 | 05-12-2007 09:47 PM |
| Hood spring Compressor | BUICKMAN | Garage - Tools | 2 | 12-24-2006 07:29 AM |
| Coil spring compressor | propaneburner | Garage - Tools | 17 | 06-06-2006 08:19 PM |
