threading consew 255 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2010, 12:05 PM
Finally getting around to practicing w/ the new maching but am I threading it right? or do I need to go up and over the little pin (green in pic) thanks for the help. Im sure I will have a lot more questions as a go along.
Old 12-07-2010, 12:35 PM
I have a Consew 225. I don't even know if I have that little pin. Try using the machine without having it go through that pin and see what happens.
Old 12-07-2010, 01:14 PM
DanTwoLakes's Avatar
Wiki Edits: 22
That tension assembly is very generic and common to a lot of different sewing machines. The pin is only there to keep the two tension discs from rotating. The thread does not go under that pin. Here's a picture of my 255 RB-3. My upper thread guide is further to the right and lower than yours, but I guess as long as your thread feeds through the two tension discs it will work all right.
Wait a minute, after further review is it possible that your thread guide is upside down? The more I look at it, I think that's the case. You also don't need to go crazy zig zagging the thread through that guide, once back and forth is plenty.
I just looked at your instruction manual. On page 4 figure 7 shows how your thread guide should be, and yours is upside down. CLICK HERE
Old 12-07-2010, 04:21 PM
Thanks
Thanks for the help. I will turn it around an give it a try. That should help a lot. When I bought the machine it was threaded up through the pin and didn't seem to work right it was real hard to pull so I took it out and it seemed to help but still didn't seem right. Dan your the man, I should be good for another night of sewing.
Wish I wasn't in the middle of nowhere I would take it to an expert. I'll have to study the manual you gave the link for, then check some adjustments. Stay tuned for more dumb questions.
Still need to order a servo before I start on my seats. I think I will get it on the way. I've been hoping to find a reliable 3000 but I think I will have to settle on the 4000. I really wanted to sew one stitch at a time because thats about how good at sewing I am.
Old 12-07-2010, 07:15 PM
Wiki Edits: 22
There aren't any dumb questions. The only way to learn is to ask questions.
The SewQuiet 3000 is not available any more, it has been replaced by the 4000. The 4000 is a better motor than the 3000, but there sure are some features of the 3000 I wish they would have left alone.
Old 12-07-2010, 10:50 PM
Much better. I turned it around like it is suppose to be and adjusting the tension adjustment works 100 times better. Figured out a few more things reading the manual. I think I'm going to have some more question on some of the adjustments, but I will do some searching and reading of the manual first. It wasn't making sense so I gave up for today. Seems to sew really good, I just wanted to verify adjustments.
My feed dogs seem a little worn, how often should they be changed? They seem to feed just fine as far as I know, the hole is a little rough looks like its been hit with the needle a few times and looks like it could maybe cut thread.
O one more quick question. I took the needle out and there are no grooves or notches. In the manual it says face them to the left(if my memory serves me right) do I have the wrong type of needle? Thanks again for all the help.
Old 12-07-2010, 11:15 PM
Wiki Edits: 27
threading machine
My son tried to use my machine and had it threaded wrong. I took a marker and drew the lines so he wouldn't have to call and have me explain how to do it.
Old 12-08-2010, 08:24 AM
Wiki Edits: 22
Your machine uses needle system 135X17. If you don't have a vertical groove on the opposite side of the needle from the scarf (the cut out just above the needle hole) you are using the wrong needle. Here are pictures of what your needle should look like. The first picture is of the grooved side, and the other picture is the side with the scarf. The scarf faces to the right, and the groove to the left.
If your machine is feeding properly now, you don't need to change the feed dog. It is rare that the feed dog would wear out so badly that you'd need to replace it. It is more likely it would get damaged first.
ID:	50683   Click image for larger version
Old 12-08-2010, 11:15 AM
Originally Posted by DanTwoLakes
Wait a minute, after further review is it possible that your thread guide is upside down? The more I look at it, I think that's the case. CLICK HERE
I'm looking at the photo and can't figure out witch one is upside down.
Old 12-08-2010, 11:21 AM
Wiki Edits: 22
The thread guide on his machine right directly above the tension assembly with the thread going in and out of it is pointing up, and it should point down. If you take that piece and flip it down directly towards you, it would be in the right position.
Old 12-08-2010, 11:53 AM
Now I see it! Thanks!
Old 12-21-2010, 08:22 AM
servo
Got my servo installed. wow what a difference, I can sew one stitch at a time. Now I can start on my seat covers. I have some top stitching to do and they need to be straight lines I'm a little worried about getting them straight.
Old 12-21-2010, 09:36 AM
Wiki Edits: 22
Pick something on your sewing machine's foot to aim with, go as slow as possible, and follow the seam the same way with the same aiming point from beginning to end and you'll do just fine.
Practice first before you do the finished work. There's no substitute for experience in anything you tackle in life, and that's especially true for running a sewing machine.
Old 12-21-2010, 11:27 AM
"Slow" is the key. If it takes you forever, it's worth it. Plus, you have to practice on some scrap. Did you also install a smaller pulley on the servo? I put a 50mm on mine and it made a huge difference.
Old 12-21-2010, 12:20 PM
Yep I have a 50mm(2 inch) pully on it, my clutch motor had one on it I was able to reuse just had to get a new belt. I tried the servo first w/ the pully it came with, about 4", because I didn't pick up a belt and I just had to try it. Then last weekend I went and got me a belt for the 2" and you arent kidding big difference. I can pretty much stop the needle anywhere. Speaking of belts how tight should it be, I can squeze it with slight pressure at midspan and can almost touch the two halfs together. Thank you guys for all the help, I can't believe I was to cheap earlier to get the servo. If anyone is considering one do it, its 100% better.
Ive been practicing on my straight lines, I think I'm ready to give it a shot but maybe I will practice a little more. I'll try it at a snails pace, I've been going slow but I can go slower. Do you just use an erasable gel pen to mark the lines with?
Thanks
just bought a consew 226: testing? etc machines Interior 17 05-28-2013 09:01 AM
Consew 255RB-2 A62WAGON Interior 10 04-21-2010 11:21 AM
Consew 206R - Sounds to cheap..... JJ269J Interior 5 03-28-2010 06:56 PM
211W155 threading instructions Elleka Interior 4 11-10-2008 03:41 PM
Consew or Chandler??? Weimer Interior 7 05-19-2004 11:27 PM
