Threading solid rod for idler pulley - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2008, 01:13 AM
Well more hand fabricating!!!!!! need to make 7'' long x 5/16" bolts for idler pulley extensions....not fun!!!!!!!! My Ford friend said he,ed weld on a allen head so i can use a allen key to tighten them to below the pulley bracket surface...Tig or mig. would they be safe and not let go???????? Any comments would be appreciated........thanks, Marty
Old 12-30-2008, 03:00 AM
I think they would hold with either tig or mig,,,but my only concern would be if the head that is welded on is absolutely,perpendicular to the thread,allowing for proper torque.I would think that if the head was a little scewed,that it might break off while you're trying to tighten them down.I'm not really sure about this,I assume that you have already made an attempt at locating bolts or screws,of this length and this thread size.I know down here in Georgia we have specialty stores where you can buy industrial fastners like this.One of hte companies that I have used in the past is called "Fastenal",,,it's one of these stores,where if they don't have it,they can order it,I think they have a website,you might want to give them a try.Good Luck
Old 12-30-2008, 05:03 AM
Another source for all sorts of hardware is McMaster-Carr. They have a website, they have an incredible assortment of items, and have super-fast shipping. They are primarily an industrial supply company, but will also sell to individuals. It's worth your time to check them out.
Old 12-30-2008, 08:15 AM
Last journal entry: Bringing home the 401 Nailhead
Will this one work for you:
http://www.grainger.com/Grainger/items/1GY13
Could not find a shoulder bolt in that lenght.
Old 12-30-2008, 08:39 AM
Thanks guys, checked out that web site & looks like exactly what I need!!!! No way I want the pulley coming loose, thats for sure!!!!!!!!!!!! Marty
stroke to rod ratio jacobm99 Engine 28 12-16-2013 06:46 PM
Junkyard Motors.. Zartan Engine 20 07-08-2011 08:52 AM
building a 1984 camaro drag car z28camaro1984 Engine 19 04-18-2005 12:38 PM
327 block parts? marcus18 Engine 9 12-24-2003 01:06 AM
?? Bore Sizes ?? ss crazy Engine 2 10-03-2003 03:51 PM
