Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Three damaged Th350s in Row ?
Old 10-23-2010, 08:04 PM
The Factory Man The Factory Man is offline
Originally Posted by 68HellCo
I forgot to flush the lines and cooler on transmission No. 3 and started it and ran it for a few minutes, then went back to flush it. Culprit?
Flushing the trans cooler is important because alot of crap gets into the cooler when you have a failure. If you install a new trans all that garbage gets returned to the new transmission and you have another failure!
