Three damaged Th350s in Row ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2010, 10:08 PM
I have put two rebuilt th350 trannys in and each got ate by a bad torque converter (I thought) that munched the pump. Then I had another highly reputable builder build a third t350 and HE installed it with a new torque converter, and the pump sounds fried again, that high-pitched screeching started right away, the one that gets louder as car is revved up. I don't know what is going on exactly. I do see what looks like a little bit of forward-to-backward movement at the flexplate and torque converter. The gap was perfect between the flexplate and the torque converter, just shy of 3/16. It's mated to a '69 Chevelle 350 motor that I took from my running '69 and put into my '71 Chevelle.
Old 10-22-2010, 10:49 PM
SSedan64's Avatar
Did you flush the Trans cooler & lines?
Old 10-23-2010, 12:39 AM
have you changed the fly wheelsome times you cant see the flex in the fly wheel i have changed fly wheels out that were bad causeing damage to trans might try this to fix your problum
Old 10-23-2010, 06:15 AM
tnsmith10's Avatar
when will it rain???
both dowel pins in place?
Old 10-23-2010, 01:42 PM
I forgot to flush the lines and cooler on transmission No. 3 and started it and ran it for a few minutes, then went back to flush it. Culprit?
Old 10-23-2010, 01:44 PM
Oh, changed to brand new flywheel and transmission pins were perfectly in.
Old 10-23-2010, 07:04 PM
Flushing the trans cooler is important because alot of crap gets into the cooler when you have a failure. If you install a new trans all that garbage gets returned to the new transmission and you have another failure!
Old 10-24-2010, 01:36 PM
OK, last question ... if shrapnel got into transmission and killed pump, what part of that tranny is salvageable for next build? And is torque converter usable and do I have to have all this stuff cleaned out in a particular way? I put about 5 miles on the tranny around town before it squeeled like a pig. Thanks, guys!
Old 10-24-2010, 09:29 PM
If It Were Me I Would Have Your Converter Checked Before Re Useing It Ya Every Thing Else Needs Tore Down A Washed Good
Old 10-25-2010, 11:56 AM
Thanks about the checks on torque converter and parts, man. Will do.
Old 10-25-2010, 12:52 PM
thats cool good luck hope every thing works out this time around
Repairing Damaged Threads - 1/2" X 20 leejoy Engine 7 10-07-2008 04:28 PM
Have I damaged my tranny? Marcus Transmission - Rearend 2 09-17-2008 01:13 AM
Can I fix damaged corvette door myself? LouisvilleLT4 Body - Exterior 23 09-29-2006 10:44 PM
We're sitting on the Front Row!!!!! Cstraub Hotrodders' Lounge 5 02-11-2004 07:39 PM
3 row vs 4 row radiator JUSTINH Engine 13 08-18-2003 01:25 PM
