Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Three different paint shops suggested 2 different ways of painting the car, opinions?
Old 04-28-2007, 09:07 PM
baddbob baddbob is offline
What color? I'd pick the shop that is willing to work best with you if their quality is good. I would want to do the final blocking just to check over the car before applying paint-the shop can do this simply by apply a coat of dry guidecoat and skipping over the surface with a block and 600 grit to verify your work before prepping for paint. The primer does not continue to flow-it shrinks like kenseth said untill full cure is reached. Full cure can be a few days or weeks depending on how the primer is applied, what primer, and temperatures.
