Three speed trans linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2005, 04:58 PM
Need help adjusting the linkage on my 55 FORD MAINLINE.I bought the car dis assembled. I have assembled it But need help with the trans linkage. The trans will not shift. I need to know i have the linkage correct on the trans and on the column.
Old 09-14-2005, 06:07 PM
David,
You didn't give me much info here. What is a Ford Mainline?
I will give you some general info for setting up most transmissions with linkage that needs to be "fitted"
I put the transmission in neutral with no linkage attached.
I then put the shifter in neutral. There should be two bars that can be adjusted at the ends. Without moving either the shifter or the transmission levers fit the linkage to their respective holes. I also like to replace the nylon bushings in the levers so the bars fit snug.
Scholman
Old 09-14-2005, 07:15 PM
help
THE CAR IS A FORD MAINLINE WITH A 3 SPEED 2.77 MANUAL TRANS MISSION. i DO NOT KNOW IF i HAVE THE SHIFT ARMS INSTALLED CORRECTLY. NOR IF I HAVE THE LINKAGE ON THE PROPER PLACE.
AXOD Ford trans rebuild advice. 4 Jaw Chuck Transmission - Rearend 22 03-16-2004 05:37 PM
ford 4 speed manual trans interchange FASTFORD Transmission - Rearend 2 01-20-2004 03:35 PM
qyestons about a 3 speed trans chevellenut Transmission - Rearend 5 12-13-2003 09:39 AM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
5 or 6 speed trans 47cnvert Transmission - Rearend 5 03-01-2002 12:08 PM
