Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Three-Wire Delco 10SI/12SI Alternator Question
Old 03-15-2011, 03:36 PM
hduff's Avatar
hduff hduff is offline
Fix it until it breaks
Last journal entry: Clutter
There's a lot of information out there about the three-wire versus one-wire alternator setup, and I'll just share this:
One-Wire versus Three-Wire
http://www.madelectrical.com/electri...hreewire.shtml
Explanation of how the idiot light circut is wired and how it works.
GM 3 wire alternator idiot light hook up
Explanation of how the voltage sensing circut is wired and how it works.
http://www.madelectrical.com/electri...esensing.shtml
And a picture of the wiring using a 1N5408 diode and NOT using the voltage sensing circut.
While the picture suggests a 10-guage wire from the alternator stud, my perference is to use 8-guage wire. And rather than pig-tail the voltage sensing line to the stud, I run a wire to the feed stud of the fuse panel so I can atually get some value from voltage sensing.
Anyway, enough sharing. My question is this:
In all I 've read it's not been clear whether any Delco 10SI/12SI can be used in three-wire mode just by connecting all three wires or if only some of the built-in regulators are capable of doing it.
What's the answer?
