-   -   Three-Wire Delco 10SI/12SI Alternator Question (http://www.hotrodders.com/forum/three-wire-delco-10si-12si-alternator-question-194535.html)
hduff 03-15-2011 03:36 PM
There's a lot of information out there about the three-wire versus one-wire alternator setup, and I'll just share this:
One-Wire versus Three-Wire
http://www.madelectrical.com/electri...hreewire.shtml
Explanation of how the idiot light circut is wired and how it works.
http://www.hotrodders.com/forum/gm-3...up-154278.html
Explanation of how the voltage sensing circut is wired and how it works.
http://www.madelectrical.com/electri...esensing.shtml
And a picture of the wiring using a 1N5408 diode and NOT using the voltage sensing circut.
http://i.imgur.com/2tJeU.jpg
While the picture suggests a 10-guage wire from the alternator stud, my perference is to use 8-guage wire. And rather than pig-tail the voltage sensing line to the stud, I run a wire to the feed stud of the fuse panel so I can atually get some value from voltage sensing.
Anyway, enough sharing. My question is this:
In all I 've read it's not been clear whether any Delco 10SI/12SI can be used in three-wire mode just by connecting all three wires or if only some of the built-in regulators are capable of doing it.
What's the answer?
T-bucket23 03-15-2011 04:04 PM
The main difference between a 1 wire and a 3 wire is the regulator. I have read that some of the 1 wire regulators will work exactly like a 3 wire if you connect all three wires and some wont. Depends on the manufacturer. Maybe this is why there is no clear cut information.
75gmck25 03-15-2011 08:13 PM
I don't think Delco ever made an OEM alternator that was designed for 1 wire operation. If you have a real OEM Delco 10si or 12si alternator, or equivalent, it should always be a 3 wire. However, if you have a Delco that was converted to 1 wire it would have a self energizing regulator.
These links explain what regulator is used in a 1 wire alternator.
http://www.purplesagetradingpost.com...o/onewire.html
http://search.waiglobal.com/partnum.aspx?part=D10SE12
Bruce
joe_padavano 03-16-2011 07:31 AM
That is what I've seen as well. If you look at the two tabs for the connector that stick through the alternator housing, some one-wire units actually have these two tabs connected by a little metal bridge strap. Obviously, this won't work as a three wire unit. I have never seen an OEM one-wire unit, though some marine applications may be set up that way.
Augusto 04-01-2012 01:42 PM
why would be practical to have only one wire to the alternator?
if for looks, the 3 wires can go inside a nice loom and would make no difference,
I have used one wire alternators and they need to be revved up to start charging, I don't like that much.
so why going one wire if 3 is fine?
