Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - thrilling moment...
Old 04-14-2006, 12:10 PM
Jmark's Avatar
Jmark Jmark is offline
Yep, I agree with Curtis. 210 is not "hot". Add some antifreeze and put the cap on!
On a side note, personally, i'd take the timing back down some for the breakin and would NOT hook up the advance until you can drive it and determine if you really do need more timing. Using more timing than you actually need, will cause the engine to run hotter than it needs to also.
Mark
