Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - thrilling moment...
Old 04-14-2006, 11:51 PM
56Maynard 56Maynard is offline
Got a fan shroud?????? If you dont, get one before you continue. If you do, fill er up with water and put the cap on and finish the break in. Personally, I wouldn't have anything but water in it until I knew everything was holding water. Coolant will kill your bearings if you have an internal leak.
