Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - throttle blip causes bog
Old 01-03-2013, 04:44 PM
KMPJ-93 KMPJ-93 is offline
The engine sounds camed, and has shorttube headers. Other than that it seems stock. I assume the electronics are for the 350 as I have extra electronis in a box of 454 parts. New distributor (including cap/rotor) and ignition coil. I don't believe this unit is HEI as it's not the big cap with power wires etc. going to it.
I never thought to check the voltage of the battery/load test, I just charged it and put it in. I will check for rubbing wires in the back.
Are you recomending I take off and clean all the grounds? (I know I shoud probably do this anyways)
