Throttle body? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2003, 10:37 AM
Throttle body?
I've got a 98 GMC k-1500 with the 350 Vortec, it runs fine but at part throttle it has this annoying jerk, it will do it in all gears if I let it. If I give it 3/4 or more throttle it won't do it, nor does it happen at just off of idle. I have been unsuccessful at diagnosing with the X-ray, must be mechanical, I guess.
Anyone out there have any ideas?
p.s. I forgot my old sign in and changed my email, so I'm not totally green with this site, just a different face
Old 11-24-2003, 10:55 AM
NorthStar's Avatar
Check the throttle position sensor, might be bad.
Watch for voltage to have a big drop while slowly opening throttle.
Dark blue wire should be about .5-.85 volt at idle and increase to about 4.5 volts at wide open throttle.
