Throttle Cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2012, 01:26 PM
Throttle Cable
Once again 69 lemans 403 v8 600 cfm holley and the throttle cable has to much slack in it with no adjustments to be made.
Do they make new ends for the throttle cables so i can just cut out the slack and put a new end on like a TV cable style or any realy.
Old 08-16-2012, 02:00 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The Lokar braided throttle kits and cables are adjustable, cut where you need for length and the ends are held with set screws.
Semper Fi
Old 08-16-2012, 02:37 PM
i was thinking of just getting the end links the cable is in good shape but its to long for a new holley is set up for a Qjet.
throttle cable stu_yoakam Engine 1 09-17-2008 11:07 PM
Throttle Linkage vs throttle cable 65comet Engine 2 06-02-2006 01:56 PM
Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) Viet Nam Vette Engine 4 06-13-2005 04:29 PM
Throttle cable bracketeer Engine 3 03-07-2005 06:57 PM
throttle cable mitmaks Engine 1 10-20-2004 08:51 AM
