Throttle cable on Demon Carb - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-09-2010, 02:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by david-b
Next question, so does the CC cable need to be connected to the same location as the throttle cable?
Yes- the CC hooks to the same place as the throttle, NOT down below- that's where the kickdown will eventually hook.
Tech @ BG is correct when he said Q-jets used a long stud to hook the throttle and CC up to the same place. You might try using a Holley p/n 20-36, p/n 20-64 or the BG equivalent.
More throttle studs, parts, etc. HERE.
Other brackets, linkage, etc. HERE.
Budget Throttle Setup Jr. Mechanic Engine 3 10-27-2010 08:55 PM
The TV Cable Can Prevent Carb From Opening to WOT JohnTN Transmission - Rearend 4 09-29-2007 08:35 PM
M4ME carb stumbles sometimes dies when letting off throttle in gear fast68 Engine 4 08-29-2007 05:57 AM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
throttle cable geometry crshrmn3 Engine 2 11-04-2002 05:38 PM
