Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - throttle cable geometry
Old 11-04-2002, 02:11 PM
crshrmn3's Avatar
crshrmn3 crshrmn3 is offline
Post throttle cable geometry
I just finished building my sbc 350, which I added an Edelbrock performer intake. Once the engine is back in the vehicle, I'll be putting on a new Edelbrock 600cfm carb with a 1/2" spacer gasket. I have installed the kit from Edelbrock onto the carb to attach the cruise control, throttle, and tv cables. The stock bracket that holds the throttle cable, tv cable (for a 700r4 trans) and the cruise control now sits slightly lower then the originally with the stock intake and Qjet. Can I still use the stock bracket or should I invest in aftermarket brackets?
