Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - throttle cable geometry
Old 11-04-2002, 02:23 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
I strongly urge you to contact
<a href="http://www.bowtieoverdrives.com/" target="_blank">http://www.bowtieoverdrives.com/</a>
The 700R4 is very sensitive to throttle cable setting and you can't assume your new carb has the proper geometry. Bowtie has a patented bolt-on trottle lever that provides the proper TV cable operation as well as an inexpensive trans oil pressure gauge so you can properly set the TV cable. It must be done by pressure.
