Throttle Linkage vs throttle cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2006, 11:13 AM
www.1965comet.net
I'm cleaning up my firewall and welding holes shut. One of my holes was for the throttle linkage to go through. I plan on using a throttle cable....
Is there any reason I need the existing hole? Can I just weld shut and drill another hole for where the throttle cable penetrates the firewall.
I new to all this and I don't fully understand how the cable works....so if I'm way off base, calibrate me....
thanks
George
Old 06-02-2006, 11:58 AM
Wiki Edits: 49
You're absolutely correct. Just weld in the hole and drill another one when it comes time to install the cable. Chances are that the cable will require a smaller hole anyway and if you're swapping engines you may want to relocate the hole as well.
Old 06-02-2006, 02:56 PM
www.1965comet.net
thank you....that's the last hole to weld and I came to check this post before I did it....
g
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
Throttle Cable problem Jag Daddy Engine 2 05-30-2004 10:07 PM
