Throttle plates will not open completely?
I am working on a 1930 model A street rod with a 350 engine and a Holley 4 barrel carb with mechanical secondarys. I have installed a spoon type gas pedal. There are 3 holes on the lever that moves the cable and I have the cable in the top hole. I have played around with it, and when the gas pedal in fully depressed, the throttle plates inside the carb are only 3/4 of the way opened. I can not seem to adjust it so the throttle plates will open completely. Any suggestions on how I can do this? Thanks
first things first.
With the foot pedal linkage not connected to the carb, will the carb open all the way?. I have rebuilt carbs and followed the instruction sheet and NOT had them work correctly, Yoy might have to heat and bend parts , add an extension on the arm etc.
Stop built into the gas peddle
Yes, I can manually open the throttle plates all the way buy pulling the cable back and additional 3/4 inch. It appears after closer examination that there is a stop built into the gas peddle which limits the travel. I might be able to grind this off to allow the cable to come back enough to open the throttle plates completely.
| i need some 45mm throttle plates out of something ... anything .. | lowROLLERchevy | Hotrodders' Lounge | 8 | 03-22-2008 07:26 PM |
| Holley 750dp 4779, are secondary throttle plates supposed to be fully open? | ESP351 | Engine | 6 | 05-03-2007 05:46 AM |
| where to buy: weber 44mm throttle plates | lowROLLERchevy | Engine | 3 | 08-18-2006 10:57 PM |
| frozen throttle plates on carb..... | onebadmerc | Engine | 1 | 08-21-2004 08:23 PM |
| Holes in throttle plates | Steve B | Engine | 2 | 02-22-2003 06:03 PM |
