Me and my best friend got to talking and decided I should drop a 350 in my truck, pull the built 4.3 out and place it in the S15 Jimmy 4x4, that I`d come out much cheaper taking this route since I already have just about all the pieces needed. My question is, I`ll be using older style 12 bolt pattern heads and not the swirly ports. Compression is 9:1, cam is OEM roller, .204 duration .500 lift. Will be adding small tube headers to the mix. Also will be using a aftermarket intake with a TBI adapter from a Holley pro jection unit. My question is, can I use a open plane intake? I have a older Edelbrock streetmaster intake that has a RPM band of idle to 4500 RPM.
I`ll be using the TBI already on the truck that`s been ported, adjustable fuel pressure regulator, TBI spacer, plus Venom Injectors. I have 2 other intakes, one a action plus and one a stealth, I know I could use these just as easy, but I wanted to use the streetmaster as I don`t have anything to use it on in future builds so I wanted to use it now if I could. Any helps greatly appreciated.
