Throwout Bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2005, 09:31 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Throwout Bearing
Anyone have a part No. or year/make/model of the GM long style throw out bearing?
Old 04-07-2005, 12:23 PM
thewrongshop@yahoo.com
Throwout Bearing
GM's bearings are all the same , but the carriers are different .
Also depends on the type pressure plate use, weather or not you
have an adjustable pivot ball...etc. Call your local parts store .
Old 04-07-2005, 12:38 PM
Last journal entry: PICTURE TEST
bearing
I believe that gm used 3 different length throw out bearings.....
Keith
Old 04-07-2005, 01:24 PM
Pony's Avatar
Check with mcleodind.com I have HP books Clutch & flywheel Handbook and it shows three GM throw out bearings: one diaphragm and two Long style throw out bearings, a stock Long style and another with about a 3/4" longer neck for use with thinner flywheels and some scatter shields. Unfortunately the McLeod part #s are four digits and the part #s in my PAW book are five digits. (Old 1600 = stock and 1602 = 3/4" longer) (PAW stock = 16001) The book was printed in 1977 so a lot has changed but I looked at their web site and they show the same three bearings under GM parts. Hope this helps.
Old 04-07-2005, 02:35 PM
The 16002 is what I need. I can get by with this I think. I use a mid plate engine moun and lose a 1/4 inch of bearing clearance coupled with a small clutch combo I lose another 1/4. The long bearing PN 16002 is 3/4 longer than the norm used on early cars and mostly trucks. I can make up the other 1/4 with an adjustable pivot ball.
Thanks a ton.
Now I'm off the part's store
Can't wait for them to ask me what year make and model
Wheel bearing repair ? jamn50 Suspension - Brakes - Steering 1 12-22-2004 08:14 AM
tiny little fish-scale-like flakes of bearing on bearing/journal bullheimer Engine 2 04-16-2004 01:12 PM
Cam Bearing Oil Hole DTL504 Engine 2 03-05-2004 10:39 PM
s-10 carrier bearing, how do you check them catscan4free Transmission - Rearend 2 01-24-2004 04:45 PM
Clutch/Throw-out bearing in 2002 F-Body dreimer Transmission - Rearend 5 08-27-2003 06:36 PM
