Thru Frame Fitting Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2008, 04:02 PM
I'm using thru frame fittings for the front brakes in my '67 Nova. After I got them installed, and brake lines plumbed, I started thinking (instead of thinking before I did all this).
The Inside Diameter of the thru frame fitting I purchased is a LOT bigger than the ID of the brake lines connected to them. Will this cause a problem with the front brakes?
I always thought that theory regarding the ID of the brakes lines were based on the smaller the better....
Thanks in advance.
Old 07-13-2008, 05:40 PM
brake fittings
Hydraulics are very foregiving. Your lines to the thru frame fittings are most likely the same size as the lines out of the fittings. This cancels out any loss or gain in pressure due to the fittings. No problem! John
Old 07-14-2008, 06:55 AM
You're correct, the output lines are the same size as the input lines.
I figured they worked, otherwise, why would they be available, just couldn't figure out how.
Thanks for the quick response!
Frame question??? Moapr Muscle General Rodding Tech 5 07-16-2007 12:10 AM
Frame question.. APalusky Hotrodding Basics 2 11-18-2006 08:01 AM
Frame Mod question johnnymopar General Rodding Tech 18 04-12-2006 06:24 PM
Rearend fitting question... Nightfire Transmission - Rearend 5 04-01-2005 08:14 PM
Frame Question. Rubberman2003 Suspension - Brakes - Steering 2 12-03-2003 01:49 PM
