Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thru Frame Fitting Question
Old 07-13-2008, 05:02 PM
dlc1979 dlc1979 is offline
I'm using thru frame fittings for the front brakes in my '67 Nova. After I got them installed, and brake lines plumbed, I started thinking (instead of thinking before I did all this).
The Inside Diameter of the thru frame fitting I purchased is a LOT bigger than the ID of the brake lines connected to them. Will this cause a problem with the front brakes?
I always thought that theory regarding the ID of the brakes lines were based on the smaller the better....
Thanks in advance.
