Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thru Frame Fitting Question
Old 07-13-2008, 05:40 PM
59 el camino 59 el camino is offline
brake fittings
Hydraulics are very foregiving. Your lines to the thru frame fittings are most likely the same size as the lines out of the fittings. This cancels out any loss or gain in pressure due to the fittings. No problem! John
