Are thumpr camshafts really not good for power? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2013, 12:56 PM
apparently everyone loves the sound of a thumpr camshaft but are the thumpr camshafts really all noise and no action or dont make alot of power?
Old 05-23-2013, 01:05 PM
Here is my knowledge. They do make decent power but they are made more for sound then the best performance. I have seen several dyno tests with the roller versions and they are not bad but the comp xtreme energy line is way better along with lunati voodoo cams. I once had the big mutha thumpr roller version and it was the worse cam I ever had as it sounded nice but ran horrible as it has a lot of overlap and I only had 6 inches of vacuum in park and way less in gear and that thing was a pain to get timing set up and carb to work with etc. The thumper cam is the least of the series and it can be made to work but if it was me I would go with something that I mentioned about above as you will not get only better vacuum but also better performance with out all the overlap those cams have and better duration number without being so far off.
Old 05-23-2013, 01:11 PM
techinspector1's Avatar
Wiki Edits: 326
I agree with what Eric said. While you can make "decent" power with such a cam, you can make more power in the same package with a camshaft that is chosen to make power, not rump-rump.
Old 05-23-2013, 01:57 PM
Moedog07's Avatar
I have had two for my SBC's. Good power in the middle and top end. Both were Big Mutha Thumprs.
Old 05-23-2013, 05:51 PM
If you want action to go with the beat of the Thumper you've got to run the compression up. Get the cam's timing specs and your compression specs, rod and stroke lengths then get on somebody's DCR calcualtor, Keith Black has a good one. You want that number to hit somewhere between (8 to 8.5) to 1 for cast iron and you can maybe push that (8 to 9) to 1 with aluminum heads.
Then this cam really wakes up.
Bogie
Old 05-23-2013, 06:34 PM
Slammedsi's Avatar
Ive got the middle of the road "Mutha Thumpr" in my SBC. Ive got to say its a dog down load. But 3K rpm and up it comes to life. This cam is in a stock compression small block. Im in the process of changing that came out for a much smaller cam with a lower lsa.
The Following User Says Thank You to Slammedsi For This Useful Post:
demarques_191 (07-16-2014)
Old 05-23-2013, 09:10 PM
spinn's Avatar
I agree with F bird. If you were serious about making power, why go with a hydraulic? Your basic solid single pattern cam , sounds serious ,and has great return on power.
The Following User Says Thank You to spinn For This Useful Post:
Old 05-23-2013, 10:49 PM
vinniekq2's Avatar
the camshaft needs to be chosen for the application. specs match your engine,not a funny name that works in everything.Its not black magic anymore,just some math
The Following 2 Users Say Thank You to vinniekq2 For This Useful Post:
AutoGear (05-24-2013), demarques_191 (07-16-2014)
Comp Thumpr Cams - Any good? Eagle1 Engine 42 09-04-2014 10:33 AM
Just wiped a lobe. Wanna try a non-thumpr now. Any suggestions so I don't lose power? Zerocyde Hotrodding Basics 26 02-23-2013 10:58 AM
What's equivalent (power-wise) to a thumpr? Zerocyde Engine 26 06-12-2012 11:59 AM
How about a thumpr sapsz28 Engine 7 11-26-2009 01:46 AM
Power example of a good combo. . . Cstraub Engine 15 01-06-2005 01:19 PM
