Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - thumpr with stock heads?
Old 12-30-2009, 02:33 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site . What cams have you been looking at do you have any ideas yet? Myself i would'nt put any thumping cam in a basically stock engine with a few more upgrades. Like heads change the springs add a set of studs and guide plates have the heads check out a possible valve job. Are you running a automatic if so do you have a stall converter thats something you should consider also. Is you car carburetor ?JMO
