Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - thumpr with stock heads?
Old 12-30-2009, 02:51 PM
sam_bo3 sam_bo3 is offline
Your not supposed to but I ran a comp 262xe with stock springs on a 73 stock smogger 350. With the steep ramp, the proper springs are a good idea especially with the constant high R's you turn with 4.10s. The stock heads should be good for 500 lift.
I looked up the 279thumpr and it calls for a 2000 stall. You might get by with a stock convertor because of your gears.
