thumpr with stock heads? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-30-2009, 10:01 PM
The key to the sound is the LSA 106*-108* will give you what you want. The dirt-track/circle -track cams are a good choice for what you are wanting. You can always pop it in N when you come to a stop sign!
6sally6
  #17 (permalink)
Old 12-31-2009, 02:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Before I'd use a poser cam, I'd just as soon retard the ignition and pull a plug wire. Instant 'lope' LOL
No, but just select a cam w/about .450"-.480" lift, 230 degrees-plus duration @ .050" lift and a 106 LSA. That way, when the fun wears off of sounding fast you can get those Vortec's and maybe actually BE fast. Or at least faster!
  #18 (permalink)
Old 01-02-2010, 08:56 PM
right cam.
I take it this is a daily driver? You are right to research this, as the camshaft is a critical component in the overall engine performance. The 882 heads are not very good and leave a lot to be desired. I have used a Comp Cams high energy 268 on a simular combo with great results. Great street cam with good driveability. I would however suggest the entire K kit. Springs should be changed, proper valve springs are a must. Also screw in rocker studs. Higher lift and faster ramp speeds can cause stock press in studs to wear or pull out. Good luck with your project!
Lt-1 cjajz Engine 13 11-27-2008 11:41 PM
Stock 350 heads 75GMCman Engine 3 11-14-2008 08:28 AM
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 01:09 AM
Building a BB Chevy. I want 500HP tommytempest Engine 30 03-06-2007 04:57 PM
Stock eliminator 78 monte Engine 5 01-02-2003 06:10 AM
