thunderbird troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2007, 07:39 PM
i have a 1988 thunderbird with a 5.0 liter mustang engine. replaced all ignition system parts ign switch, computer, ecm. starter relay, coil, cap, wires, rotor. it will start run fine for 10-15 miniutes then just shuts off dead. any ideas??????
Old 11-01-2007, 12:42 AM
aka Duke of URL
When it cuts off, have you traced the cause to ignition and/or fuel pressure? A noid lite will make the ignition/injector firing easier to ascertain. Do you have a scanner?
Usually, when one shuts down like this, it is either the TFI module and/or stator.
mustang II/ thunderbird rack question sfd771 Suspension - Brakes - Steering 7 05-12-2012 08:57 AM
1979 Thunderbird Trim RenoValron Body - Exterior 0 09-26-2005 06:54 PM
ThunderBird IRS ...Rear End Swap to 8.8 sum87mustang Transmission - Rearend 1 08-26-2005 05:27 AM
any mechanics done suspension work on 88 thunderbird needed here! FoxThunder 5.0 Suspension - Brakes - Steering 12 08-03-2003 02:12 PM
74 Vette 350 engine troubles KnumbKnuts Engine 2 03-22-2003 03:31 PM
