ticking - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2008, 09:48 AM
ticking
Hi I have a 454 in my 52 chev truck when i start it and let it warm up it starts to tick Good oil pressure rockers are tight changed the lifters .any ideas ???? what it might be.
Old 12-02-2008, 10:20 AM
ticking
may be your rockers , did you inspect the ball rocker cups .
also you sure that its inside motor .
i have had noises that sound like ticking only to be exhaust leak .
leaking out bolt hole on my wrecker .
have a belt slapping also making ticking noise on a 350 in another truck .
your rockers not hitting valve cover ?
Old 12-03-2008, 08:13 AM
ticking
Thanks burnt olds
i checked all that everythings good
i used a scope and i can here it on the pass side of the motor.
Old 12-03-2008, 09:42 AM
Originally Posted by truck52
Thanks burnt olds
how old the timing chain ?
are you running the stock fuel pump ? can you un-bolt it and give a listen ?
the rod to it , maybe sticking or bent causing it to have lash making ticking noise .
hook up a lawn mower fuel tank and hang from hood to run long enough to try .
swap rocker arms if you have some extra's , are they riding all dead center on top of valves ?
i pulled hair for days to find out my exhaust was my problem on my 73 chevy wrecker , stock manifold leaking out bolt hole .
have lots to tell me i need to adjust valves ,till i show them the leak .
ticking small block mhamilton Engine 10 07-02-2006 06:12 PM
ticking sound sbc Chevy Hi-Po Engine 13 12-28-2005 12:02 PM
Mysterious Ticking cutsupreme Engine 2 07-19-2004 12:53 PM
need help, motor ticking! 70chevelle327 Engine 2 03-03-2004 04:38 PM
Ticking Noise Jeff Christenson Engine 9 02-23-2003 07:17 PM
