ticking noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 11:35 PM
ticking noise
Hello to everybody I'm new to hotroding I just recently picked up a 83 c10 with a built 355
And today while showing it to a friend I noticed a ticking noise then when I got inside and looked at my gauges I have no oil pressure at idle and it hadn't done this before. What could it be some have said it could be my crank shaft bearing others have said cam bearing I'm not realy shure what to do could someone give advice
Old 04-27-2013, 12:33 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
First of all, check the oil level. Do you have a mechanical or electric gauge? A mechanical gauge will have a small line running to it instead of a wire.
Old 04-27-2013, 06:19 AM
delawarebill's Avatar
pressure ??
what was it before it went to zero? maybe the oil pick up screen pipe fell out..
Old 04-27-2013, 09:21 AM
I check the oil everyday its full but it normally stay around 20 to 25 psi but when i start driving it it goes to normal
Old 04-27-2013, 09:55 AM
And at idle its 0
ticking noise 83Montecarlols Engine 2 01-27-2011 05:37 PM
Ticking Noise mightycarlo10 Engine 13 09-18-2008 07:34 AM
Ticking noise Meka Engine 3 12-18-2003 04:00 PM
Ticking Noise Jeff Christenson Engine 9 02-23-2003 07:17 PM
