You might also check out the 5th down picture. Look closely and you can see what looks like a nice dig into the rocker body right dead center where the trunion is. To the left side of the stud in the picture. I would look at that carefully and possibly replace that one. At the very least sand or file that raised area down, clean it with laquer thinner and look at it REAL close.
always on a Ford
I always cut the guide plates and pair them . when 2 guides are tied together you cant align them properly. it makes no difference who the maker is Cut them in half and set each individually to align each push rod. I have always had perfect alignment this way. And we Raced at 8000 Rpms no problemeo
Since I can't find the same rockers anywhere, should I replace all the rockers or can I just replace the bad one with a different brand one? If so, recommend me one to buy; if not then recommend a good set.
If I'm not mistaken, they have ERSON on the roller end. If so, have you tried to get hold of Erson Cams to see if they still make them?
Yeah, I looked for "Erson rocker arms" several times and never found an official website. Since you mentioned "Erson Cams" I looked that up and it seems that they are now possibly owned by pbmperformance and it seems that they still sell the rocker arms in sets. I'll contact them, Thanks.
Several weeks later (earlier this month) I was rolling down the road.. going about 15mph and the ticking got louder. I had a dead miss and a shudder on acceleration. I drove the 10 miles home and pulled a valve cover. I looked at the rocker that had originally been ticking. It was fine. I pulled the other cover and didn't see anything either. I pulled all the rockers and while leaning over the engine put my hand on a valve and.. I felt it push down some The spring was broken.. The valve didn't contact the piston however. Quote:
That the intakes are sunken and the exhausts aren't takes unleaded fuel out of the picture for the most part. What may have happened is the intake seats were bad enough that the seats had to be sunk that far to get the seats back during a valve job, or an incompetent machinist botched the valve job.
| Tags |
| 302, ford |
| lifter ticking | ted200008 | Engine | 5 | 06-09-2011 06:21 PM |
| cam/lifter/rocker ticking | delawarebill | Engine | 16 | 03-10-2011 11:27 AM |
| 1974 454 ticking sound | Torque454 | Engine | 7 | 02-28-2011 04:09 PM |
| ticking sound sbc | Chevy Hi-Po | Engine | 13 | 12-28-2005 12:02 PM |
| ticking sound | Lightspeed | Engine | 9 | 12-26-2002 11:34 PM |
