Tie rod / Ball joint tapers - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2004, 07:46 PM
ken47's Avatar
Does anyone happen top know (or direct me to where I can find out) what the taper is on GM and Ford ball joints and tie rod ends. There appear to be two different tapers (well at least two) a 1 1/2" per foot and 2 " per foot taper. These reamers are available, but I can't seem to home in on which one is for what application.
Thanks
Ken47
Old 01-27-2004, 08:05 PM
willys36@aol.com's Avatar
Wiki Edits: 21
This is the one I bought from Speedway Motors to use on early Ford ball joints. Also used it on a steering arm for my '53 Chevy pickup and it worked there too. I use the 1 1/2"/ ft.
Speedway Motors tapered reamer
Old 01-28-2004, 05:04 PM
The 1 1/2 is the most common.
Old 01-30-2004, 10:01 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
I scored on a reamer at BSR they sell that left turn stuff. They always keep that stuff in stock 704 795 0901 ask for Kool Aid They close at 2 on saturday. Tell him I told you to call If shipping becomes an issue let me know I've got a UPS account
