Tie rod collar safety factor. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2011, 06:27 PM
cboy's Avatar
Last journal entry: Finished
How much tie rod thread needs to be within the tightening collar to retain a reasonable safety factory when adjusting for alignment.
The first photo shows how far I had to adjust in order get the passenger side wheel into alignment. The arrow indicate the end of the exposed thread. There is 15/16 inch of thread within the collar on each end. In the second photo I slid the tightening ring to match the end of the tie rod thread to give you an idea of how much thread is in there. I will be able to tighten the rings firmly over the threaded ends on each end but is this enough rod to be safe.
Always learning...and sharing what I've learned.
Old 09-02-2011, 08:02 PM
The rule I was always taught was that you had to engage equal to 1 dia. ex. , 1" bolt =1" thread. I think I'd fab some longer unsplit sleeves w/ jam nuts . Just seems those split sleeves would be a little flimsy. my .02
dave
Old 09-02-2011, 09:10 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Sounds about right, but I would also ensure the clamp was clamping a threaded portion.
Semper Fi
Old 09-02-2011, 09:42 PM
cboy's Avatar
The tie rod is 7/8" and the enclosed thread is just a hair more than that. So I may finish it up this way. But I like the idea of a longer sleeve and jamb nuts. Just gotta find somebody locally that can make one up for me (I don't have the facilities to do the right and left hand threads at that size).
And I'm with you NovaSS, I just slid the clamp down the sleeve to show the end of the tie rod within the sleeve. They'll be clamped directly over the threads.
Old 09-03-2011, 09:51 AM
What about "sleeving" the split -sleeve?
dave
Old 09-03-2011, 10:46 AM
Frisco's Avatar
Glad To Be Here
Steering and its components should be much better than "Reasonable".
Threaded connections have maximum strength when there is a length of 1 1/2 times the diameter being engaged. With the split sleeves and only the length of threads in each end of the sleeve AND having so much exposed split area in the middle, I wouldn't trust the connection as shown.
Old 09-03-2011, 04:35 PM
cboy's Avatar
...What about "sleeving" the split -sleeve?...
Hmmmmm, got any pictures, drawings or explanation of how one would go about that?
Old 09-03-2011, 05:02 PM
user151's Avatar
dave
I do not recall seeing a sleeve split the entire length. But be that as it may, the use of jam nuts defeats the old school look.
Old 09-03-2011, 05:27 PM
I'm thinking a piece of tubing of the appropriate dia. to slide over the split sleeve, then plug weld so the split sleeve won't open or bend ??
dave
P.S. between the clamps.
Dodge 4X4 shift collar oldred General Rodding Tech 3 03-03-2010 05:36 PM
Blue collar Christmas Carols WakBordr7387 Off-Topic 3 12-07-2005 11:33 PM
8 1/4 pinion crush collar wildfire78 Transmission - Rearend 2 08-07-2005 11:16 AM
blue collar tv mustangman1968 Hotrodders' Lounge 2 07-30-2004 08:07 PM
9 inch crush collar shagginwagonvic Transmission - Rearend 8 01-08-2004 08:51 PM
