Tie rod/draglink clearance and front suspension travel question
I finally have my front end together and I am having a couple of issues. Here's what I have:
It's a 4" drop I-beam axle with 4-bars. I have a Vega box installed that may have to be moved back - the pitman arm is interfering with the tie rod. My plan is to try a stock Vega pitman arm with the offset in it to clear (the bolt head that connects the rod end to the end of the pitman arm is rubbing on the tie rod). Moving the Vega box back is complicated by the motor plate bracket on the frame. My question is, how much clearance do I need between the bottom of the frame and the tie rod? I only have an inch right now and that looks like a disaster waiting to happen on the first bump I hit. I plan on notching the frame above the tie rod and drag link, I just have no idea how much a pothole could cause the front axle to move. Other than jacking up the car on one side @ the wheel, is there a better way to determine how much it can move? Thanks! |
Here's a pic of the clearance
At some time (maybe many times) in the cars life, the suspension will move until something hits the frame, bumpstop or the shock bottoms out unless the spring is so stiff that it can't. If you remove the tie rod, determine how much clearance the supension has in bump until the next thing hits, like the axle to the frame for example. If that is enough travel for you then that is how much clearance you need for the steering linkage. I would recommend at the very least 2'' of bump travel before you hit a bump stop, 3" is better.
Andy |
Thanks, I'll do that. Exactly what I was looking for!
Thanks Frisco... I have been looking for different length pitman arms, and Speedway just started carrying the stock Vega items, which I ordered to see if it clears. The steering arms are flat (Speedway 37 - 41 style spindles). I considered the 3.75" lowered steering arms, but that puts it exactly where the lower 4 bar is. The "stock" steering arms have a 1.75" drop from the mounting holes, but that pretty much puts them where the flat ones are (although they do look much better).
This is my first build, so I am learning on the fly about this (What can be bent, what can't, geometry of the components, etc) so I really appreciate the information. Thanks again! |
Some combination or slight modification will work.
| Front Shock Travel with Air Ride | 71gtx | Suspension - Brakes - Steering | 0 | 06-29-2009 02:33 PM |
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| 57 Bel Air Wheel clearance Question... | TheHaloEra | Suspension - Brakes - Steering | 3 | 06-01-2006 01:31 PM |
| Suspension Travel for my I-beam 32 | LittleTruck | Suspension - Brakes - Steering | 5 | 01-16-2006 09:52 AM |
