Tie rod hitting oil pan 67 Chevelle 350 small block
Installed new 350 crate engine in my 67 Chevelle. The tie rods are hitting the oil pan. Any solutions besides dinging the oil pan?
They are through the paint. Steel showing. Seems to be on right more than left
oil pan
what oil pan are you using?what was in car before?
The pan came as part of the 350 crate engine
oil pan
what engine/oil pan was in car before?
the crate engine more than likely has a truck pan..
what mounts and stands you use.. ? I'd just dimple it and call it good |
Thanks! My garage said the same thing. I am looking for a long term solution including changing pan, mounts, or steering system. Any ideas?
MS |
also 307 mounts are different, not sure what the difference is (taller,shorter,off to one side) but that may help/hurt but worth looking into.. or hack like I did, adding 1/4" washers between the block and stand lifting the engine 1/4" you'll need longer bolts.. cheap and easy.. (note may need to add washers under the tranny mount if the driveline gets a vibration from u joint angle, mine didnot need any.. |
| Big block pil pump on small block Chevy | dallam11 | Engine | 22 | 03-24-2012 07:36 PM |
| small block big block weight difference | Jmark | Engine | 3 | 02-04-2008 12:21 PM |
| can i use small block motor mounts for a big block? | 402 Camaro | Engine | 5 | 01-25-2008 07:33 AM |
| are 1 5/8 long tubes too small for a 414 ci small block? | tony350ss | Engine | 8 | 03-17-2003 11:45 AM |
