Tie rod to oil pan collision?! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 05:13 PM
Thanks to this forum, I fixed my power steering today. Unfortunately, it led me straight into my next problem. When turning to the right, my tie rod ball joint slams dead into the side of my new oil pan! Its to the point that a little "Massaging" of the area with a ball peen hammer was no use. Is there any way around this without pulling the pan off for a different style? I have heard of the 4x4 guys using a "drop" style pitman and idler arms, but has anyone ran into this before? I have my '65 chevelle driveable with no leaks, and cant stand the thought of pulling the pan. Please advise if you can.....
Old 07-11-2010, 06:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What engine do you have in the car ?
Cole
Old 07-11-2010, 06:14 PM
Its a 383, but it had a worn out 327 in it when I bought it, so I know a small block should fit. Its a 300 deluxe that originally had a straight six. I put a new Summit stock oil pan back on it when I built the 383, and it seems the old original pan had more of a radius around the bottom near the dampener. The Summit pan is more sqaured off right in the area where it hitting.
oil pan selection, what would you pick chevy1500z71 Engine 3 01-13-2010 08:29 PM
Replacing Oil Pan Gasket on 1972 Nova 454 With Motor In Car - Help leejoy Engine 17 04-28-2008 01:58 PM
MustangII...Inner/Outer Tie Rod Ends Sweet-34 Suspension - Brakes - Steering 3 06-02-2007 05:35 AM
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 07:21 PM
